Showing data from earlier geoquestions
1029
06-16-2021 04:45 AM
AlexanderRossel
Hi
Lets say I have instances of geotrace. Can I have the input from the first show on the map of the second geotrace?
Maybe there is an obvious solution to this, but I can't seem to find it.
Cheers
Alex
BrettStokes
Hi @AlexanderRossel ,
You just need to add the field name of the first geotrace into the calculation column of the second (and subsequent) geotrace questions. For example:
Hope this helps,
Brett
AlexanderRossel
Thanks for your reply Brett. I appreciate the support!
Your solution is almost the thing I seek. However, I should have specified that I only want to show - and not edit - the previous input. With the procedure above I have to edit or replace the existing input from the first geotrace:
What I'm looking for is a way to trace a new feature and only visualize my previous input simultaneously.
So I could have something like this:
Where the red line is drawn in the second geotrace.
I hope it makes sense.
BrettStokes
OK, I understand your requirement now. Unfortunately, this is not currently possible. We have a beta feature that allows a similar (but different) behaviour for repeats with point geometry only. You can see your repeated points on any map in your survey. See the Early Adopter documentation for details.
Brett
