show most recent child record date in parent layer using survey123 connect
1255
05-27-2023 02:57 AM
tendtreesTC
I'm trying to show the date of the most recent audit (which is recorded in a repeat field) and also the result of that audit in the parent feature layer.
Is there a calculation I can use in survey123 connect to find the most recent child record and then draw attributes from that into the parent record?
tendtreesTC
For anyone who may come across this post I found a solution.
I use the indexed-repeat calculation to return the value from a repeat.  In order to find the most recent repeat I use the count calc.
The complete calculation looks like this:
indexed-repeat(${audit_date}, ${inspection_audit},count(${audit_date}))
tendtreesTC
