Hi All,
When multiple users are collecting data, is there a way to view, on a single mobile device (not portal / Arc), the location for all of the users survey location?
Ideally there was a way to load all the surveys on to each device and view all the records on the map, the location of each survey.
I know this can be done in Arc / Portal but there isn't a way that I know of you can avoid duplicating survey locations without looking at screen shots of Arc or Paper maps drawn onto.
I know Survey123 stores the data on the phone in folders but I'm not sure
1) how to export that to a spreadsheet, hopefully with XY data
2) If you can export it to a spreadsheet, how to re-import all of them to a device and have the device be able to see the locations that were included in the spreadsheet/database
Is this possible currently?
Cheers,
-Curtis
