Sharing of survey results causes error "Cannot get answers for this question. Details: unable to find the field in related feature service."
613
04-21-2021 04:42 AM
DeonLengton
Step 1 - Publish a new survey to AGOL
Step 2 - Capture some test data and view it in the Analysis tab - everything looks fine
Step 3 - Share the survey's results with the organization
ERROR for some fields - Cannot get answers for this question. Details: unable to find the field in related feature service.
I know that a view is created from the Feature Service and it seems that this view is having issues because before the view is created the Analysis tab shows the data correctly but after the view is created (when sharing the results of the survey) then some fields give the above error. Between publishing the first time and the view being created there have been no change to the published service.
Can you assist please @ZhifangWang
Tags (1)
