Share View Results Page
3536
11-05-2015 06:36 AM
GlenGardner
If a survey is published to a organization group could the view results page be viewable for all those in the group? I tried to send the link to others in the group but, it did not allow them to view the page. The view results page looks like it is using operations dashboard code. If the sharing of the site is not available is the code available to publish separately in the organization?
FasilTiru
Glen,
Just a quick suggestion, if you want other members of your group to view the results, please consider using the 'View map in ArcGIS MapViewer' link. As you can see, the View Results options is available under 'My Surveys' and the items listed here are the surveys that you own.
Your members can open the web map and then click view table to see the results.
Fasil
FasilTiru
Glen,
Fasil
HariharNepal
hello FasilTiru, I tried to share results using collaborate tab, it does not work. There i no "share survey result" link available, and when I click on "save" button, it gives me error "failed to save", the error message is something like
....._results' already exists...
..."tokenExpires":...
can you help me?
