Set hint text using URL parameters
1323
11-03-2023 02:12 PM
JohnNergeBrooklynPark
I'm playing around with URL parameters to customize some text in my survey (built in Web Designer). It's working great using a Note, but I'm wondering if it's possible to use URL parameters to dynamically set hint text for questions?
The specific use case is for people renting a park building. When they click on a link from my web map pop-up, it'll direct them to survey with the park already selected (eventually I'll hide the single choice question so they can't change it). I can write the note text just fine using URL parameters plus some html/css formatting. But it'd be nice if I could put that text as the hint for a single choice question so that the details I want them to review and the button they need to click to confirm are right next to each other, vs. needing the extra question heading.
IsmaelChivite
Esri Notable Contributor
IsmaelChivite
Hi. @JohnNergeBrooklynPark Lucky you! It works! See below.
Thank you for this, @IsmaelChivite, what a clever way to do it! Following your instructions, I added a single text field, called parkdetails, hid it and set it to not submit an answer. Below is the URL I was then able to use, included an image to show the results. I'm generating the link in a web map, so it can also plug in attribute field values so the details will be custom to the park building the person opens the rental form for.
https://survey123.arcgis.com/share/<surveyID>?field:parkdetails=<div style="font-size:1.25em;font-style:italic">Please review your rental details</div><br/>Capacity: {CapacityField} guests<br/>Resident | Non-resident fee: ${ResFeeField} | ${NonResFeeField}
Thank you again so much, this is EXACTLY what I needed!
