Hello!
I have a scenario where surveys related to properties are compiled mostly in office and not on site.
The Survey is already set up to pull data from a layer when the point is placed on the polygon, but when the survey is submitted from office, the customer is lamenting that the point is not in the correct location.
Of course this could be solved by opening the map and place the point in the right location.
so, given the fact that I can pull info from a polygon, I was wondering if the opposite is possible: select a property from a list and create the geopoint of the survey in the centroid of that same property.
This has to be dynamic as property can change quite often.
Thanks!
