Seeking recommendations on how to solicit web map feedback from the public
1943
7
10-24-2022 11:05 AM
ScottHansen__MDP_
I am looking for a way to gather public (non-AGOL user) feedback on a web map that includes the following:
  • Users would be able to drop one or more points on a map and leave a comment(s).
  • Users would be able to view map layer attribute information.
The Map survey template within ArcGIS Hub and Survey123 does not meet our needs as it does not allow a user to drop multiple points and comments to a map. It also does not allow users to view map layer attribute information.
Your help is appreciated.
HarshithaDondapati1
Hello Scott,
I'm Harshi, PM on the ArcGIS Hub team.
Thank you for sending us your enquiry regarding public feedback gathering on a map. ArcGIS Hub has a feedback tool that released in 2021 which makes it easier for the public to input geographic data using full-screen, mobile responsive maps. Here is a blog link that explains how map-based feedbacks work - https://www.esri.com/arcgis-blog/products/arcgis-hub/constituent-engagement/gather-community-feedbac....
We also have a new feature we will be releasing soon- discussions  that facilitates conversation(posts, replies) on a webmap, dataset (or any content item) to facilitate deeper feedback collection within Hub.  https://www.esri.com/arcgis-blog/products/arcgis-hub/sharing-collaboration/coming-soon-hub-discussio.... I am glad to set up a call to demo map-based feedback and discussions and get your feedback on both!
Thanks!
ScottHansen__MDP_
Hi Harshi,
I am aware of the map-based feedback, however, there appears to be some limitations. I was not aware of Discussions and would like to take you up on your offer to discuss further. I will send you a DM with my email address.
MelissaSalich
Do you mind sharing the solution or workaround you used?
I'm having a similar problem, we want a web and mobile friendly web map for community to comment on multiple parking locations.
The mobile capabilities are lacking in the configurable apps/WAB/ExBldr.
ScottHansen__MDP_
I cannot believe that ESRI still has not come up with a good solution for a crowd-sourced map application. I used ArcGIS Web App Builder, then created a dashboard theme, then used an "About" widget to provide instructions, then the "Smart editor" (which for some reason, I can no longer find in the widget choices) so that users can click on a point location and then edit certain fields. The web map and any layers you want the public to edit must have "Public data collection" enabled in the options menu.
Here is a screenshot of the application:
MelissaSalich
I agree!
Thank you for sharing your work around.
I contacted support today and it is a known defect, BUG-000161705.
They're working on it...in the meantime we'll have to be creative...
ScottHansen__MDP_
Please clarify if the bug you are referring to is the missing "Smart Editor" widget, or something else.
MelissaSalich
My apologies, I've been all over the Esri Community today!
The BUG is related to the ExBldr Edit Widget not allowing just for a 'Create Features' function.
See this post: https://community.esri.com/t5/arcgis-experience-builder-questions/remove-the-select-edit-part-in-edi...
