Search() Appearance in Web Survey
3122
10-17-2021 09:46 AM
mattkramer
Hello,
I recently read about the new Search appearance for select_one and select_multiple questions and am really excited to get it deployed in current surveys.  I have my search functions working in Survey123 connect, but once I publish and test in the web application, the spatial query built into my search appearance does not seem to fire when a new geometry is set.  Is there a way to turn on this functionality or is this not available in the web form currently?
Screenshot from Connect with a spatial filter working:
Screenshot from the web version:
Here is the appearance related to this question:
minimal search('CountiesInAOI?url=https://services.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/USA_Counties/FeatureServer/0','int...})
ZacharySutherby
Hello @mattkramer
I'm not seeing the same behavior on my end with the attached XLSForm. You will need to publish the survey from Survey123 Connect 3.13 which is the latest version of ArcGIS Survey123.
Thank you,
Zach
ZacharySutherby
Hello @mattkramer
Thank you,
Zach
mattkramer
I found the issue. I had 'intersect' as my search type, while you have 'intersects' in your example.  That s at the end got it to work online.  Thank you for the example that helped me figure that out!
