Hello,
I'm using a repeat geoshape question in a form I built in Survey123 Connect (version 3.11.123). I am using the expression "method=vertex Color=red" in the body::esri:style column to make sure that the shape can be collected using vertex points. In our workflow, the user interacts with the form on their computer using the ArcGIS for Survey123 app (verson 3.11.164). When the user in the survey123 app on their desktop computer, the geometry of the polygon changes between what they draw and what is submitted with the form. This does not happen when the form is filled out on an iphone, and I assume other mobile devices though I haven't been able to test all.
Is this a known issue? Is there a work around?
Things I have tried to troubleshoot:
1. Remove the method=vertex
2.change the basemap from a custom webmap to a standar map
3. uninstall and reinstall the ArcGIS for Survey123 app on the computer.
Thank you!
@IsmaelChivite @JamesTedrick
