S123 Connect bind::esri:fieldType
3316
05-24-2023 04:00 PM
MelissaSalich
I'm new to S123 connect and want to make sure I'm following best practices.
Is it ok to leave bind::esri:fieldType blank?
Unsure the difference between the type column and the bind::esri:fieldType column.
IsmaelChivite
Esri Notable Contributor
Hi. Yes, it is OK to leave it blank. When you do, Survey123 Connect will automatically map the XLSForm question type to the appropriate Esri field type:
XLSForm Question TypeArcGIS Field Type
text, select_one, select_multiple,calculate, hidden, email, start, end, deviceid, barcode, note.Text
integerInteger
date, datetimeDate
decimalDouble
geopoint, geoshape, geotraceGeometry (point, line, polygon respectively)
file, image, audioAttachment
Sometimes, you want to set a value in the FieldType XLSForm column. Common cases include:
  • When you want to work with GUID fields
  • When you want the question to have NO corresponding field in the layer: Use null.  See details here.
  • When you want to store a calculate or select_one as an integer column
  • When you want your geopoints to store Z values. See details here.
IsmaelChivite
integerInteger
date, datetimeDate
decimalDouble
MelissaSalich
thanks for the great explanation!
