RoadVista 922 Retroreflectometer and Survey123
1448
06-29-2021 08:49 AM
NathanBruce1
Just wondered if anyone has been successful in transmitting sign reflectivity scores using a RoadVista 922 and transmitting the data via Bluetooth to one of the Esri mobile field apps, in particular Survey123.  There is only one post from 2012-2014 in the community that relates to Windows Mobile and 922 and doesn't really address this problem.   Wish to use the transmission to record the scores to eliminate human error and improve efficiency.
ArcGIS Mobile and RoadVista 922 Retroreflectometer
JamesTedrick
Esri Esteemed Contributor
Hi @NathanBruce1 ,
Integration with an external device like the reflectometer would require some work in the Survey123 app or an extension to interface correctly.  This would make a good potential idea to consider in the future; also, I would recommend reaching out via your account manager to the Survey123 team on this.
by Anonymous User
Not applicable
I would love to do the same. Commenting in hopes a solution is found, or possibly already has been?
NathanBruce1
No solution was found. Considering a different reflectometer.
