Retrieve survey responses from outbox
682
08-30-2023 11:32 AM
ErinMara
One of our field crew didn't update their survey versions before collecting a week's worth of inspections, so we now have quite a bit of data to retrieve from his outbox on his mobile device.  The survey was originally published using Survey123 Connect, and has since been deleted.  How can I retrieve all that data?
Katie_Clark
Yikes, that's no good....a very familiar story though, unfortunately!
Anyway, your best bet is to try to recover the sqlite database off the device. You can try looking at this documentation or this support page to start.
Good luck!
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
