Republishing error: "Info file for item not found" (Critical, code 400)
1668
08-16-2021 11:45 AM
RSchaffner
I created a survey in 2018 with Survey123 Connect v. 3.9. I have updated it numerous times, the last being in August 2020. I just made some more changes, but when I tried to publish using Survey123 Connect v. 3.12.230, I got the error "Info file for item not found" (Critical, code 400). The changes were simple-additions to a choice list, not a schema change. I looked at the files in the My Survey Designs folder, and it doesn't appear that anything is missing. I've attached a zip file of the survey with all the associated files. The only thing I can think that might have happened is that I originally published it with a generic "Form_1" name, like the names assigned when you create a new survey without changing the default name. Then at some point, I renamed the .xls and folder from Form_1.xls to Closed Landfill Inspection Reports.xls, etc. Maybe I missed a reference to the old name somewhere. But if I recall, I had done that before the last update, and it worked at that time. Could it be a Connect version issue? How can I resolve it? Thanks.
Tags (1)
ZacharySutherby
Hello @RSchaffner
If possible would you be able to share the survey to a group with ZSutherby_Survey123 added to it? I don't need access to the underlying data just access to the survey. With access to the survey I can compare the files with the published survey and the zip attached to identify any differences that may be causing the publish failure.
Thank you,
Zach
Thank you,
Zach
RSchaffner
Hi Zach-
Thank you-I have invited you to a group called DEP Arc Collector Test (or something like that) and shared the survey form with the group. (My AGOL username for that account is Becky.Schaffner@maine.gov, but I can't use that account for posting in this forum.)
Becky
FieldUser1One
Has there been a solution to this problem?  I've just encountered it for the first time.
