I edited the choices to an existing survey and republished it successfully however these changes are not reflected in the feature layer in arcgis online. What else do I need to do to see this change? (urgent!!) The changes are available in the app but not online.
Hi Vanessa,
Survey123 Connect does not currently update the domain when republishing surveys. This is partially because if values have been entered that have been subsequently removed, those would not be displayed. As a workaround, you can manually update the domain with the values; see Updating Hosted Feature Services in ArcGIS Online | ArcGIS Blog
Thanks very, James, this seems like the right answer however I am unable to save the changes. I have only changed the choices options for one list but cannot update the service:
T
Thanks very, James, this seems like the right answer however I am unable to save the changes. I have only changed the choices options for one list but cannot update the service - please see error message.
Can you provide a copy of the UpdateLayerDefinition text? JSON is highly structured format that is easy to get a bit wrong. you can also try validating at http://jsonlint.com - it's good for checking that the text is valid.
This is the section that I have updated but the errors seem to be from existing code. I changed the code for "Unsure" and added "Mauve". The code saves ok but then if I try adding new point data Mauve is still not showing as an option.
{ "name" : "bandLT", "type" : "esriFieldTypeString", "alias" : "Band colour - LEFT TOP", "sqlType" : "sqlTypeOther", "length" : 4, "nullable" : true, "editable" : true, "visible" : true, "domain" : { "type" : "codedValue", "name" : "cvd_bandLT", "codedValues" : [ { "name" : "Make Selection", "code" : "ms" }, { "name" : "Unsure", "code" : "Un" }, { "name" : "Black N", "code" : "N" }, { "name" : "Orange O", "code" : "O" }, { "name" : "Green P", "code" : "P" }, { "name" : "Mauve U", "code" : "U" }, { "name" : "Yellow Y", "code" : "Y" }, { "name" : "White W", "code" : "W" }, { "name" : "Blue B", "code" : "B" }, { "name" : "Red R", "code" : "R" }, { "name" : "Pink K", "code" : "K" }, { "name" : "Metal M", "code" : "M" }, { "name" : "Wild (unbanded)", "code" : "Wild" } ] }, "defaultValue" : null },
Yes, the JSON looks good. You can remove the other parts of the Service definition - the UpdateLayerDefinition requests only really needs what has changed (deletion of items looks more like changing to blank values)
Sorry I don't understand.
My apologies, I may have mis-read the above comment. Did the update save correctly? You say it saves okay, but then mention the other areas presenting errors. If it still isn't submitting successfully, you can reduce the amount of text being submitted to just:
{ "fields" : [ { "name" : "<FIELDNAME>", "domain" : <YOUR DOMAIN INFORMATION> ] }, "defaultValue" : null } ] }
As opposed to the full definition
The changes in code looked to be saving but I just closed out of the update tab and re-opened and the have not been saved, presumeably due to the other two error messages that appear (pre-existing). I will try and update using only the section of code relating to that choice list.
James,
Will this be an enhancement within version 2.0? After some reading that I have done I was under the impression that the domains were updated if you did not change the form schema?
Which is confusing after having the dialog within Survey123 Connect referencing that your data will remain even though we are republishing? IT WOULD be awesome if the survey could be updated to include "New or Additional" Domain values, but not allow for the removal of previously posted domains.
Hi Mike,
The behavior has not been revised as of version 2.0. In our documentation, we refer to choice lists, which can be stored as domains (but are not required to); the revision of choice lists does not result in a schema change. I've added this request to our development backlog for evaluation & prioritization.
Thank you for the response. Two more question, but does this same logic apply to using pulldata or external picks; in terms of the FGDB Domains not being updated with the picklists?
Last question, when I do go back and update the choices or the comma-delimited text file from the media folder for the external picks; will the answer of the newly added choices show up within the FGDB feature class or related table? If so, then that is an acceptable behavior for me.
I do greatly appreciate the information.
Mike
Signed in members can post, follow updates, and more. New here? Register a free account.
