Report Generation in MS Powerpoint
936
11-05-2018 06:46 AM
AndrewHargreaves2
I'm beginning to investigate the use of the Reporting out of Survey123. As it uses standard MS exporting functionality is this something that can be leveraged with MS Powerpoint?
JamesTedrick
Esri Esteemed Contributor
Hi Andrew,
The report template functionality currently does not support PowerPoint files.  Can you describe the scenario that you would like to have slides generated?
AndrewHargreaves2
All of those great stats I can automate using the Survey123 Reporting API into word I want to be able to 'present'  to a customer. Storymaps and dashboards don't work, as I can't guarantee I'll have sufficient connectivity, nor do they allow me to print something out and send it to the customer as a deliverable. The word report is awesome for being a deliverable, it's just not great to present a word document.
