Repeat is broken in Survey123 web app
1237
04-14-2017 09:19 AM
AlekKreiger
#survey123 repeats#survey123 web app
When publishing a survey from Survey123 Connect version 1.10 to AGOL and viewing the survey in the Survey123 web app the repeat group does not allow users to add additional responses. The plus  and minus  buttons do not show up. The repeat works as it should in the form preview in Survey123 Connect. I've published surveys this way before with a properly functioning repeat group and don't believe I've done anything differently this time.
JamesTedrick
Esri Esteemed Contributor
Hi Alek,
Can you retry loading the survey?  Apparently, we had a mis-publish of the website code - an in-development change went to the production website by mistake.
AlekKreiger
Yes, it works now.  Thank you for the speedy response.
