Reordering Fields in Attribute Table in Survey 123
1633
06-03-2022 03:50 PM
SarahRadel
I have created a Survey in Survey 123.  Whenever I open the attribute table the fields are not in the order that the questions are asked in the survey.  How do I reorder the the fields in my attribute table?
ClayDonaldsonSWCA
The attribute table order when viewed in say, the web-app or web-map would be based on the feature layers pop-up order.
If you need the exported data to be in a specific order, you would need to overwrite the forms related feature layer with the correct order.
ClayDonaldsonSWCA
Teresa_Blader
This does not seem to work with the new map viewer, reordering the fields in the popup. There are 20 something fields to reorder, to use the up and down arrows in Map Viewer Classic is too tedious. @ClayDonaldsonSWCA  Am I doing something wrong or are you just using the Map Viewer Classic?
Teresa Blader
Olmsted County GIS
GIS Analyst - GIS Solutions
ClayDonaldsonSWCA
Yes - the reordering would be done in map viewer classic if using a web-app builder app.
Alternatively - you could set up an experience with a table widget, much easier to reorganizer there.
Teresa_Blader
That's a really great suggestion with the Experience table widget. This project has about 25 surveys to edit, so I think that'll work pretty smooth! Thanks!
Teresa Blader
Olmsted County GIS
