Related table with "duplicate" attribute names in the main survey
334
04-16-2020 06:36 AM
DeonLengton
So I have a survey with a main table and a related table (repeat)
Some of the attribute names are similar in both the main table and related table
Is there a way in Survey123 to differentiate between the two by using the "table name"/repeat name as part of the attribute name?
I need to use the attribute in a calculation and obviously Survey123 isnt sure which attribute i am referring to in the calculation.
JamesTedrick
Esri Esteemed Contributor
Hi Deon,
Apologies for the delay.  It isn't possible to have duplicate question names in a survey when they are used by calculations.
