Reference Error: x is not defined in expression: x
3973
08-18-2023 06:18 AM
MariusVerdes
Hello everyone,
Hope you are all doing great. He got 4 surveys that are created based on the same feature layer from our ArcGIS Enterprise and recently I got an error that says "Reference Error: x is not defined in expression: x"
And I don't know how to solve it. Each of these surveys has set a default value for the field "country" to ease the user from choosing this every time. I tried to create another survey based on the same feature layer with the same configuration but without the default value for country and the error is gone. But I want to have a value set for the country depending on each survey.
Does anyone know how to resolve this issue?
Cheers!
smukahhal
smukahhal
MariusVerdes
Hi @smukahhal ,
Thank you very much. Indeed the instance_name column was the issue here. It is weird to be honest because it was set up like that for a few months and the reference error started to pop-up just 3 weeks ago.
Anyway, thank you again.
