Rearrange table columns in Data tab of Survey123 web site
432
09-09-2025 08:47 AM
JayHodny
Hello Survey123 users!  I had a request to rearrange columns in the table view under the Data tab in the Survey123 web site.  I can drag/release columns in the order requested, but the change seems to be temporary.  If I refresh the browser window, the column order reverts back to its initial order.  Is there a way to reorder the columns and have the new order persist?  Many thanks in advance for any help.  Sincerely, Jay
Neal_t_k
The table order you are seeing is the order of the columns in the Feature, the only way to permanently adjust those is to basically re-create the feature again with the order of the columns you would like.  If you built that feature  using survey123 you would need to adjust the questions in the order you would like to see on the data table and republish the form.
A workaround could be to have users look at the data through dashboards or Exp Builder where you can format a table with the order of the columns they see.
Neal_t_k
JayHodny
Many thanks Neal for your reply, much appreciated.
