Re-Submitting a Survey
228
06-22-2023 02:09 PM
Blevins_Mark
Is there a way to re-submit a survey with repeats (and photos attached to the repeats) that is in the sent folder if the record is deleted, for instance in the survey123 website? I enabled editing of the sent folder and tried to edit and re-submit, but this did not work as the original record can not be found. I have also tried the copy to new survey option, but this does not include the photos attached to the repeats. Thanks.
ZacharySutherby
Hello @Blevins_Mark
Copying to a new survey does not maintain the attachments, but since the record is in the Sent folder the attachments will still reside in the My Survey Attachments folder. What you can do is copy the record to a new survey then browse to reattach the images from the My Survey Attachments folder for the image questions. This will be located in the ArcGIS folder typically in:
iOS:
On My I<device>/Survey123/ArcGIS/My Survey Attachments
Android:
<local storage>/Android/data/com.esri.survey123/files/ArcGIS/My Survey Attachments
Windows:
C:\Users\<username>\ArcGIS\My Survey Attachments
Thank you,
Zach
