"Note question contains a value in the name column," but there is no name!
911
05-26-2023 06:12 AM
AnnaScholl
After running the analyze survey tool, there is a notice that
Note question contains a value in the name column:
However, none of my notes have a name in the name column! (outside of the generated notes). What's going on here? !
AnnaScholl
I copied a known empty cell to all the note names, and solved. The problem happened likely from web designer to connect.
AnnaScholl
