"Continue this survey" results in duplicate records?
1410
10-31-2016 07:55 AM
bobwright
We have been training field staff in the use of Survey123 for deer check station work this coming weekend. One of them discovered what appears to be a bug when presented with the connectivity on "Survey Completed" options. If one chooses the "Continue this survey" option, returns to the form, makes changes (or not), completes the survey, then chooses "Send Later", an extra record is found in the Outbox. If "Send Now" is chosen, the duplicate record is also generated and is sent along with the intended record. If one chooses to "Continue this survey" a second time an additional record is generated. We have found that additional record is generated each time e.g., you choose to "Continue this survey" 5 times for a particular survey, 5 duplicate records are generated. We have documented this on Windows, Android and iOS platforms.
bobwright
I forgot to mention that it is version 1.8.21 for all 3 platforms.
JamesTedrick
Esri Esteemed Contributor
Hi Bob,
We have this issue logged and will be working to fix it.
JakeMatthys
Plus 1 for this issue...
