Python for ArcGIS Not Downloading Survey123 Report
280
09-26-2022 08:54 AM
jvarasanz
New Contributor III
Good morning.
I'm using the following code to generate a Survey123 report, but none of them are downloading to my disk since yesterday.
survey.generate_report(template,
where=f"GlobalID = '{GlobalId}'",
report_title=report_title_temp,
output_format='pdf')
I understand the report is downloaded to my temp file under C:\Users\xxxx\AppData\Local\Temp, but I look for it and it is not there.
Please advise.
Javier
ZacharySutherby
Hello @jvarasanz
If you check the recent tasks for the reports in the Survey123 website there should be an error for the reports that failed. What is the error in the Survey123 website?
Thank you,
Zach
