@pulldata Query (Feature Service/Layer)
1162
03-14-2024 07:32 AM
GaryBowles1
I am trying to query a feature service using @pulldata in the calculate field. I am receiving the following error:
...:Couldn\'t understand the expression starting at this point: ...tStatistics=[{"\xcd\x8estatisticType":...
Here is the pulldata request:
pulldata("@layer", "getValue", "attributes.field1", "https://gis.srcx.com/server/rest/services/APPS/APPS_RUN_LOG_BINGHAM_MR/FeatureServer?outStatistics=[{"statisticType": "avg","onStatisticField": "field1","outStatisticFieldName": "field1_avg"}])
The feature service is the same one that the Survey points to.
Survey123 Connect 3.19
ArcGIS Enterprise 11.1
--gary
ZacharySutherby
Hello @GaryBowles1
The quotation marks in your outStatistics string is throwing off the URL string.
You'll need to use something like:
pulldata("@layer", "getValue", "attributes.field1", 'https://gis.srcx.com/server/rest/services/APPS/APPS_RUN_LOG_BINGHAM_MR/FeatureServer?outStatistics=[{"statisticType": "avg","onStatisticField": "field1","outStatisticFieldName": "field1_avg"}]')
Thank you,
Zach
GaryBowles1
Thanks Zach I will give it a try and let you know what happens.
--gary
