pulldata() function from CSV, doesn't works
1989
10-15-2021 07:18 AM
by Anonymous User
Not applicable
Hi everyone!
We tried to use pulldata function in order to extract information from CSV into a survey, however this function does'nt works.
Survey is too simple, we need some fields has populate when we select a name from a list. That's all.
We try to replicate an example from web and neither doesn't works.
Maybe somebody knows what happen?.
Thanks a lot.
CMT (Technical Monitoring Centre)
2 Solutions
DeonLengton
Hi
You have done everything correctly except that your CSV file has semi-colons (;) instead of commas (,) in.
Replace the ; with , in your file and it will work.
AllisonHollier
The problem isn't your syntax, it's your spreadsheet.  I believe it has to do with parsed data to columns.  Or at least, it worked when I did it.  See attached.
DeonLengton
Hi
AllisonHollier
See, and I always avoid commas at all costs.  LOL  Different workstyles!
by Anonymous User
Not applicable
Deon, your're absoutely right.
My CSV has semi-colons (;) instead comma (,), I didn't realized that detail. I'm sure that's about regional configuration.
Thanks a lot.
CMT
AllisonHollier
by Anonymous User
Not applicable
Allison, thanks for your time.
Your're absoutely right too, I had problems with regional configuration so CSV file was saved incorrectly. I replaced CSV file on the media folder and it works perfectly.
Thanks!
CMT
