Pull data doesn't work on hidden questions?
630
07-21-2021 01:49 PM
by Anonymous User
Not applicable
I have a web form, in which location-related questions (lat&long, state, county, zip, address) are auto-populated by the pulldata function.  This works fine, but once I hide those questions the pulldata function stops to work.  Is this an expected behavior?
jcarlson
MVP Esteemed Contributor
I haven't seen this behavior myself, pulldata questions functions seem to work fine. Can you share those parts of the XLS spreadsheet? Or specify which kind of pulldata is being used?
And can you do a test submission from Survey123 Connect to verify that the hidden pulldata questions are truly not working?
- Josh Carlson
Kendall County GIS
