Publish Survey123 Connect with repeats not working
5241
16
04-06-2022 11:51 AM
janderson_ksninc
I have created a survey in Survey123 Connect from a hosted feature layer with a point layer and a related table to hold the survey results. After I published the hosted feature layer, I was asked to add a couple of repeats to the form. After adding the repeats, the survey would not publish/update. After doing some reading, I learned that I am not able to add repeats to an existing survey and publish it (unless I'm mistaken). I then recreated the survey by copying over the survey questions/choices, etc from the first survey to the new form.
Now, when I go to publish the survey, I get the following error:
Does the hosted feature layer need to already have tables for the repeats added to it prior to creating the survey? Can anyone help with this?
janderson_ksninc
I also noticed that your example differs from mine in that your Form ID is pointing to a point feature layer (PFCLentricForm) and your repeat also points to a point feature layer (PFCLentricFormWaypoints) whereas my example has a point feature layer and an actual table that are related to each other.
DougBrowning
MVP Esteemed Contributor
My example was a feature yes but normally I do tables.  Sorry bad example but it should make no diff as long as they match.
Yea this label one is really weird.  Cannot say I have seen that on before esp since you do have one.  Maybe you copy pasted and did not use Paste Values?  I would just try changing the text maybe it does not like the 1 or something and maybe paste in from the row above to fix the validation.  Weird one. This post says its just a warning and not a big deal https://community.esri.com/t5/arcgis-survey123-questions/suppress-question-has-no-label-warnings/td-...
I also see you have a reserved word on Condition.  Could be some of the issue.
But your main problem I think is fixed so you can use it on the original survey.
Hope that helps
janderson_ksninc
@DougBrowning- I guess the part that I'm struggling with is the fact that I don't want the survey results to go to the point layer but rather I'd like the survey results to go to the related table. If I change the Form ID to the point layer, doesn't that defeat the purpose of having a related table to hold the survey results? The label issue resolved itself btw, wierd.
DougBrowning
Well you can make the repeat the form but then you need to fill out 1 form per repeat record.  Hard to tell not knowing your workflow.  But the form has to have a top level that goes somewhere.  I guess I am not sure what the top level is that you do not want to edit.  What you want to do is just a bit funky.  One idea is a dummy parent layer and then feed the repeat to the other table.  Sorry not much to go on.  You can pm me if you like.
Amarz
If you are attempting to repeat the same point with new data, could you reference the Form ID from the same survey?
janderson_ksninc
GarrettRSmith
Hi @janderson_ksninc have you found out how to make this work?
I am also having the same issue and wanted to know if you have found a workaround?
I am trying to use a table for the Form ID and then two repeats that point to a polygon and line feature class. When I try to publish the survey I get an error stating:
"Parent layer id 2 not found for table CampsiteArea".
CampsiteArea is a polygon feature class.
