I am having trouble implementing the pulldata function using Survey123. I have a CSV file that contains road names and the district associated with the road. That CSV has been put into the media folder of my survey. I believe my calculation formula is correct. When I go into my survey, the district simply doesn't populate or return any value. Any help would be appreciated. A screenshot been added below.
Hi Anthony,
Your pulldata syntax looks to be sound (assuming your StreetAddress matches your ${Street} values), but I am wondering what the reason is for utilizing the calculate question for the process instead of just using the note question to apply the pulldata function?
It seems that your note question is simply reflecting the value derived in the calculate question.
Are you able to share your XLSForm with subset of the information in your CSV? If so, please upload to this thread or I can send you a personal message upon request.
Thank you,
Brandon
Hi Brandon,
I am not able to share the XLSForm. If you could message me, that would be great. In regard to the calculation/note setup, i was trying to follow a template I saw and make it work for me. It does seem irrelevant but I wanted to make sure it would work before I started messing around with everything.
Anthony
I have sent you a private GeoNet message providing you with my email.
As shared via email, it is necessary for the external dataset being referenced by the pulldata calculation to be in CSV format. After changing it from an XLSX to CSV, it appears to be working as desired.
Best Regards,
I am having the same trouble using pulldata function in Survey123. In my case, I have a select_one question to select a municipality (as a label) and write down the XY coordinates (municipio_xy). I am trying to use that field as a link to store the name of the municipality (municipio) and an ID of each one (id_municipio) from a CSV file. That CSV has been put into the media folder of my survey. I belive my calculation formula is correct. When I try to capture (Survey123 App or Suevey123 web) it does not fill the fields as expected. When checking the generated survey123 service these fields are always Null.
I share some images of what I'm trying:
My Survey:
My choices sheet:
My CSV file (placed in media folder):
I have invested some time in discovering what could be wrong. Could you help me see if there's something I'm not seeing? Could it be that the key field between the survey and CSV file is complex? (I've tried with the ID field with the same result).
Hi Leydi,
Can you open up the CSV file in a text editor? In countries that normally use a comma as the decimal mark, 'CSV' files use a semicolon (;) as a separator.
Hi James,
Thanks for your answer.
I just checked the CSV file in a text editor and I had effectively changed the commas for semicolons. Now I tried my survey again but I still have the same problem.
I tried changing the fields that should be brought from the CSV as note type. Even so, Null appears.
Can you share the form files?
Hi again,
I have attached my form file (TEST) and CSV file (municipios_pulldata).
I am also having this problem, the live survey shows the options that my pull data labeled, however it does not auto populate. One reason is I think that my list in choices nay not be correct.
I am unable to share the data specifically so I left the screen shots as generic as I could
Is this the correct save file name that is in the media file?
Hi All,
Jumping in with a different issue. I am wondering if you are able to utilise the pulldata function for a survey you created in connect but are viewing on a web browser?
Your help will be appreciated.
Hello ,
I am facing also an issue in the pulldata function if the CSV file contains arabic !! any support ?
I am dropping the form(capacity) and the csv(public)
Thanks !!
Signed in members can post, follow updates, and more. New here? Register a free account.
