Problem with Calculations on Edit existing Survey123 forms in web dashboard.
942
01-24-2022 01:35 PM
chelynnes
Above are the time calculations I'm using in my form. They work great in the field app, but as soon as I try to use these calculations in a simplified form for the web survey123 (for edit existing), they refuse to work.
I have read posts about switching them to read only, but the yellow fields are customer facing and must be read only.
I see this has been an ongoing issue since at least 2018. Has anyone found a workable solution to get the calculations working in the web edit existing?
chelynnes
I've done more testing and it doesn't appear to work in the webform, even when I'm not editing existing entries. Web Survey123 should be able to do calculations, what's going on?
