Possible to turn off map controls for a geopoint map?
1322
07-30-2021 06:38 AM
AndrewRitchie
Is it possible to turn off the map navigation controls for a geopoint map?
I've built a 'pin drop' survey using Connect, which is only intended for use through the web app.
I'm using a number of geopoint maps and using a custom basemap. Given that the area of interest is quite small, users won't even need to pan the map, so I wouldn't mind locking the extents as well.
by Anonymous User
Not applicable
Hi @AndrewRitchie,
No, it is not currently possible to disable or remove the map navigation controls in the web map or field app.
If this is an enhancement you would like to see in the future, I would suggest raising on enhancement with Esri Support, and also creating an Esri Community Idea so the feature can be voted on.
Regards,
Phil.
by Anonymous User
Not applicable
Hi @AndrewRitchie,
Regards,
Phil.
