Have a repeat in Survey123
yet when I view the form in AGOL the pictures from the repeat do not show up as an attachment, only the signature.
Hi Carl. You cannot see the attached images in the popup because the photos are attached to a related table in your feature service. If you would like to have more than one photo show in your popup, the best option is to add multiple image questions to your survey outside of the repeat.
ichivite-esristaff are there any future enhancements to allow that functionality?
ichivite-esristaff can you suggest a course of action to resolve this issue, with already uploaded forms? I am aware of the steps to recover photos from the iOS app, but using AGOL can I add the photos to the related table?
When I view the related table in AGOL, I do not see a link or attachment to the photos. Is this caused by the photo in a repeat?
Hi Carl,
Unfortunately, attachments of related records (i.e., photos of repeats) are not viewable via the table of the Map Viewer. They are viewable at the survey123.arcgis.com website and via the 'Data' tab of the ArcGIS Online Item Information page.
I am able to see the inspection in the survey123.arcgis.com/Data tab but once again the pictures within the repeat do no show up. Only the signature, that is outside of a repeat.
cqholt Did you find a solution for this?
I also have a feature service with an image reapeat in a seperate table. When I update my survey a new feature service is created wthout the original data. What I'm trying to do is to export the pictures in a repeat and upload them in a new feature service.
What I see when I view the Data view of the feature layer in AGOL.
