I am trying to pass a parameter form the main form to another form as link. it works well when you set a value
concat('<a href="arcgis-survey123://?itemID=ec998f5e1d984bc5bb139c6e85040e7f&field:province=Basrah">237 Daily
Report</a>')
Now I want to replace Basrah with the value entered in the main form
concat('<a href="arcgis-survey123://?itemID=ec998f5e1d984bc5bb139c6e85040e7f&field:province={Province}">237 Daily Report</a>')
The proble it fills in province a text {Province} without getting the value in {Province}
Hi Oussama
You're almost there! Please try something like this (note the commas and single quotes):
concat('<a href="arcgis-survey123://?itemID=ec998f5e1d984bc5bb139c6e85040e7f&field:province=',${Province},'">237 Daily Report</a>')
With concat() the values to concatenate must be separated by commas. The concat() function is described here: https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
Also to reference another question in a calculation, use the ${question_name} syntax.
Hope this helps, please let me know how it goes.
Best regards,
Jim
