Order repeat by most recent records
603
09-25-2024 02:29 AM
ColinCampbell1
Is it possible to return the records in a repeat so that the most recent record is shown first?
At the moment the form displays the record entered first and you have to scroll to the last repeat to get the most recently entered one.  For processes where you are carrying out inspections you usually want to see the most recent inspection record first without having to scroll through many others to get to it.
I've seen some other posts suggesting using something like orderBy might or might not work for repeats, but I can't find out any info to implement that even if it does work.
Any help people can offer would be greatly appreciated.
DougBrowning
In the app no there is no way.  But to help you can long press the forward repeat button and it will go right to the last record.
DougBrowning
