So, after many many hours of work and research, I was so excited to finally get my complex survey built in Survey123 Connect ready to publish.
The survey is big. The XLS Form has 187 rows, there are five different .js files with multiple functions in each of them. There are external choice lists with thousands of different species names for the region, which use the "pull data" function to autopopulate their indicator status. There are also many other calculations and dependencies built within the form.
I thought I was already doing what was recommend as "best practice" for large surveys (i.e. using the Page style, using external choice lists, etc) but even with doing all of this, the survey crashes on iOS (apparently related to a bug that is supposed to be fixed in the 3.14 version release of the field app). When opening on Android, it doesn't crash but the survey takes 2.5 minutes to open.
Is there anything else I can be doing to help optimize the performance of my survey that I'm missing? Or was Survey123 just "not built" to handle surveys like this?
