open an excel sheet from within a survey?
490
07-06-2018 09:37 AM
LynnBerni
Is it possible to open an excel sheet from within a survey, to do some quick calcuations needed to answer one of the questions?  And then have a field in the spreadsheet populate a field in the survey??  Specifically, we have a simple streamflow calculator , and Avg Flow (CFS) is what we want answered in the survey.
Just wondering....
Thanks!
Lynn
JamesTedrick
Esri Esteemed Contributor
Hi Lynn,
It is possible to use an appearance of calculator to display a simple calculator on the form.  That being said, if you want to embed a calculation like the streamflow calculator, you can do so by having calculations in the survey - see New Mathematical Functions Make your Form Smarter and Formulas—Survey123 for ArcGIS | ArcGIS
