Once() not working in new body::esri:visible column
957
05-19-2022 12:46 PM
ByronTsang
In an older (pre- body::esri:visible functionality) survey, I used the once() function in my Relevant expressions to turn fields on as needed, but to retain them if the upstream relevance trigger was changed.  That function seems to no longer work in both the Relevant and body::esri:visible columns.
In both, I'm finding that changing the field that triggers relevance/visibility continually re-evaluates, seeming to ignore the once() function entirely.  Did something change? am I missing something obvious?
ZacharySutherby
Hello @ByronTsang
One alternative workflow you can use is use a calculate question to store the once calculation, then set the relevancy based on the calculate question.
For example:
typenamelabelcalculationrelevant
select_one yes_noexample2Example select_one question
noteexample4Example 4once(${example2})
textexample3Example 3 ${example4}='yes'
Thank you,
Zach
ZacharySutherby
Hello @ByronTsang
For example:
Thank you,
Zach
ByronTsang
Thanks, Zach - I'll give this a try.
