NULL date and/ or time field from Survey123 Connect throws an error in Microsoft Power Automate Flow
1581
12-15-2023 10:24 AM
DarrenLloyd__DOIT
Context
I created a Survey123 Connect form which has been published. In the survey form I have a field for Date and a field for Time (two separate fields) neither of which are required to be filled out. When a survey is submitted a Microsoft Power Automate Flow is triggered which sends an email.
Problem
Because the Date and Time fields are optional and sometimes not used, they come into Power Automate as NULL which throws an error message. How can we allow NULL values in Flow or replace the NULL value with a string 'no information provided'?
These are example of the errors.
The Survey has date but NO time
The survey has NO date but has time
DarrenLloyd__DOIT
I ended up using a Condition Control (yes or no) with a Compose data operation for No Date and Yes Date.
abureaux
MVP Frequent Contributor
You will need to user either parallel branches or a conditional statement (probably the more natural choice of the two).
DarrenLloyd__DOIT
