Note Field Formatting Within Survey123 Connect
1969
02-01-2022 07:21 AM
DaveK
Hello!
I'm using a calculation to pull text from a text input field into a note field within a survey built using Survey123 Connect. Is there any way to format the note field to increase and bold the text size? Any help is appreciated.
Tags (1)
Katie_Clark
Rather than using the calculate column, you can add HTML tags directly into the label column:
Example output:
Would that work for what you need to do?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Example output:
Best,
Katie
DaveK
This is perfect! Thanks for the help.
