Nested Repeat Position Issue retrieving from Inbox
2891
10-29-2021 12:21 PM
LarryWiebe
Hi All,
I am having a problem with a very dynamic survey where the position it returning a wrong value in a nested repeat when retrieving a survey from the Inbox.  I have attached my survey supporting lists and a screenshot walkthrough of the issue...  All data is in the service properly, but the windows/android 3.13.234 and iOS 3.14.182B clients have all shown the problem.
Larry
DougBrowning
MVP Esteemed Contributor
With nested repeats position(..) gets confused so you need to be specific.  position({repeatname})
Hope that does it
DougBrowning
Hope that does it
LarryWiebe
Thanks Doug, your solution and looking at what we had found an issue with missing .. and tightened up out nested repeats by adding the position(${repeatname})!
THANKS!
