Nested If/Then statement error in Survey123
1480
12-13-2021 10:34 AM
EileenWeppner
Hello All,
I am working in Survey123 and I need some help with an If/Then statement. I am getting the following error when trying to convert the XLSForm:
B”ODK Validate Errors:\n>>Something broke the parser. See above for a hint.\nError evaluating field ‘leftcbavgheightnum’: The problem was located in calculate expression for ${leftcbavgheightnum}\nXPath evaluation: cannot handle function ‘If’\nCaused by: org.javarosa.xpath.XPathUnhandledException: The problem was located in calculate expression for ${leftcbavgheightnum}\nXPath evaluation: cannot handle function ‘If’\n\t… 10 more\n\nResult: Invalid”
Here is the calculation (If/Then statement) I wrote:
If(selected(${leftcutbankheight},'0'),0,If(selected(${leftcutbankheight},'<5'),2.5,If(selected(${leftcutbankheight},'6-10'),8,If(selected(${leftcutbankheight},'11-25'),18,If(selected(${leftcutbankheight},'>25'),25,0)))))
{leftcutbankheight} is a select one/text field
The result of the If/Then statement is a numeric decimal field ({leftcbavgheightnum}).
I am pretty new at Survey123. Any help would be much appreciated!
Thanks!
Eileen
DougBrowning
MVP Esteemed Contributor
My first guess is if should be lowercase.  So if not If.  It almost seems like that is what the error is saying.
The second guess is it thinks <5 is HTML.
Try that.  Hope it works.
DougBrowning
EileenWeppner
That was it!!
Yes, the problems were "If," "<," ">," and "-" ....changed to "if," "less," "grt," and "to"
Thank you so much!!
