Multiple Photos in Survey123
41731
42
09-16-2015 08:28 AM
TonyStrothers
We are wanting to use Survey123 for a field inspection form and we were wondering if Survey123 can be set to take multiple pictures without having to set each picture as its own field. Either one picture or 12 pictures. Does anyone know if this is possible? If so, how is it done?
Thanks!
Tony
by Anonymous User
Not applicable
Hi Pat,
No, if you remove the repeat and re-publish the survey from Connect it will not delete and create a new feature service. Simply the repeat is removed from the survey form, however the related layer still exists in the feature service with the related data and attachments.
Note that moving the image question from the repeat (related layer) to the parent layer will mean the attachments are now being stored against a different layer. If you have existing data and surveys collected already this will mean that attachments for old and new surveys would now be in a different structure and layer. You may want to consider this before making the change, especially if this is on a production survey with already collected production data.
Regards,
Phil.
PatriciaAlgura
Hi Phil,
It's not yet in production, but these are very useful information. Got that and will take those into consideration.
Thank you!
IsmaelChivite
Esri Notable Contributor
Patricia Algura‌  A few additional details about multiline appearance for images at: https://community.esri.com/groups/survey123/blog/2020/08/07/survey123-tricks-of-the-trade-photos
