Hello,
We are wanting to use Survey123 for a field inspection form and we were wondering if Survey123 can be set to take multiple pictures without having to set each picture as its own field. Either one picture or 12 pictures. Does anyone know if this is possible? If so, how is it done?
Thanks!
Tony
Solved! Go to Solution.
Is there anything else that needs to be done for the pictures to get attached to the collected feature? I followed the instructions as described above and in the help, but when I send the survey back to the feature service, and download the layer as a SHP or FGDB, the images are not being downloaded with it. Also they won't display in AGOL.
Hi Ernesto,
here are a couple of things to look at:
What would be you suggestion If I need the user to writ caption for the images they take.
Thanks in advanced ,
Iris hadar
I would suggest a description field
Sent from my iPhone
I do need a description field, so can you be more specific?
This is what I have done but the next image appears even if I don’t want to
add another one and it is a bit confusing to the user
Image_field_1
תמונה 1
text
SPIC1
תיאור תמונה 1
Image_field_2
תמונה 2
$!="" text SPIC2 תיאור תמונה 2 $!=""
thanks
iris hadar
בתאריך יום ד׳, 18 ביולי 2018, 16:34, מאת Jevita Webster <geonet@esri.com>:
GeoNet <https://community.esri.com/?et=watches.email.thread>
Re: Multiple Photos in Survey123
reply from Jevita Webster
<https://community.esri.com/people/Jevita_Webster?et=watches.email.thread>
in Survey123 for ArcGIS - View the full discussion
<https://community.esri.com/message/785515?commentID=785515&et=watches.email.thread#comment-785515>
Hi Iris,
Have you tried using the relevant statements for both the second image question and description (text) question to make them not relevant until there is an answer for the first image and description question. This way the second lot of questions only show up once the first ones are answered.
Phil.
thank you so much for your answer, i was looking for download the attached images as well
I also had this configured in my form through a repeat, and the image question is required. However, if the user tries to delete all the records within the repeat, the question will no longer display; and they can continue submitting surveys without attaching any images. Also tried requiring the repeat group if it would do the trick, I checked that it's working on the field app but not on the web form.
Is there a way to disable deleting the first record in a repeat?
Thanks!
Hi Pat,
No, it is not possible to disable the delete button on a repeat. Have you tried using the new multiline appearance for image questions, so that you do not have to use a repeat, that way they can add multiple photos but the image question will always be required, meaning they must add at least one photo. You can also use constraints to control the min and max number of photos allowed that way.
The only other to achieve this with repeats would be to use a count in a field outside of the repeat to count the number of repeats added, and base a constraint on that number to alert the user and stop them submitting if the constraint is not met. Otherwise you could try use repeat count, but that would force the number of repeats as set.
Regards,
Phil.
Wow! Just tried using multiline, solved my problem. Looks like the best option for me.
Follow up question, would my FS id update if I remove my repeat? Thanks
