Merge/Aggregate Survey123 from responses for Ops Dashboard
631
04-20-2020 11:02 PM
GavinTaylor1
Hi
I have setup a number of survey 123 forms with the identical set of questions for different operations (8) in our company. I would like to dynamically aggregate the results into a single table/view so that I can setup a dashboard showing aggregated data as well as data by operation. Is this possible? I cannot figure out how to do this with ArcGIS online. Or is there another approach I should be considering?
Thanks in advance.
Gavin
JamesTedrick
Esri Esteemed Contributor
Hi Gavin,
Apologies for the delay.  It isn't possible to automatically add the records of different tables together - you could append the data from the tables into one feature layer.
Another technique would be to have the forms all submit data to the same feature service - that way, you would have one table receive all the records, which could then be used to display the results in other applications
