Map question in Survey 123 also retain/record actual address entered/found?
1028
08-06-2020 06:29 AM
by Anonymous User
Not applicable
Hello!
We have a Citizen Hurricane Damage Report survey that allows citizens to search/find their address on the map and it adds a point.  Super helpful since it does the heavy lifting for geocoding and ensures we get a complete address from the user. However, when reviewing the actual report data I don't see the actual address listed anywhere just the lat/long coordinates.  Is there a way to have a map question and retain the actual address entered/found?  The tax department needs both the mapped point and the actual address entered.
Here is the survey: https://survey123.arcgis.com/share/d3efd0fd3fab4635ab9120faab5aa4ee
It was created using the web designer.
Thanks!
JamesTedrick
Esri Esteemed Contributor
Hi Angela,
This looks to the same as the question you asked at https://community.esri.com/groups/survey123/blog/2016/11/03/extracting-information-from-geopoint-que...  - is that correct?
by Anonymous User
Not applicable
It is!  I wasn't sure that other thread was active anymore so posted an individual question.  Thanks for responding!
