I'm using MAKE to automate report generation and route it to specific emails. Once in a while the scenario will stop and the error will say "maximum number of repeats exceeded". Which is strange because there are no repeats in this survey. On the MAKE community board, searching for this error message gives zero results.
In this case I didn't realize the scenario had stopped. After turning it back on, it ran without any errors. Has anyone ever received this error, do you know why it occurs and how to mitigate it?
Hi Mike,
I see one mention of this error on Make's site, and it says it has to do with to length of the job's duration.
Because it ran the second time you tried, it looks like it was an external factor (e.g. not because you were trying to submit attachments that were too large) although file size could be something to look into if it continues happening.
Hope this helps.
@MikeOnzay @rwrenner_esri We are seeing this error ourselves today with our scenarios that involve ArcGIS Field Maps....
Was there ever any resolution to this? We are dealing with the similar issue...it always works fine when we restart the scenario, but having the scenario stop each time this happens is a problem.
