Make an answer to a question identical to a earlier question.
1024
07-29-2020 08:38 PM
by Anonymous User
Not applicable
   At my organization we take environmental survey building. Each building is identified and many measuremenst are taken inside each building. I have created a form that is separated into two groups. The first group identifies the building that is surveyed, in a field named "Location" and the serial numbers of the equipment used. This first group is only filled out once and is non-repeating. The second group consists of the specific measurements that are taken inside the building that is mentioned in the first group. This second group is a repeating group and has many records per building.
   When I export the data from the second group into an excel sheet, it would be very useful to have a defaulted column that is set to whatever the "location" field, selected in the first group.
SMauri
Hi Sam,
I can recommend exporting data in GDB format and then using Join Field in ArcGIS Pro/ArcMap to have desired field in second group.
Cheers
Stefano
DougBrowning
I do this by adding a calculate or hidden field in the repeat with a formula of ${field I want} so it brings in the value.   You have to give it a different name so that there are no dups but other than that it works fine.
Hope that helps
