limit map points to just those in current survey
411
05-06-2024 12:05 PM
Blevins_Mark
i have a survey from which a feature report is generated when the survey is submitted. the report has a map section. is there a way to limit the points that show on the map to those that are only part of the submitted survey, ie not show points from previous surveys in locations where multiple surveys may exist. currently i am doing this with a time filter on the layer in the map that is included with the feature report, but this may be problematic. is there a way to limit this based on the information called within the feature report itself?
thanks
