Leyer appearance in strange format
1161
09-21-2023 01:20 AM
DrJumaKhudonazarov
DrJumaKhudonazarov_0-1695284321074.pngI am trying to create a map with layers but it appears in the storage format  I have a screenshot  it. Any advice on what is going on here?
ZacharySutherby
Hello @DrJumaKhudonazarov
You will need to either publish a new layer or overwrite the existing layer and when you publish the layer the map coordinate system will need to be set to Web Mercator.
Thank you,
Zach
ZacharySutherby
Hello @DrJumaKhudonazarov,
If you are viewing this layer in a map question within Survey123 the layers will need to be in Web Mercator Auxiliary Sphere spatial reference.
Thank you,
Zach
DrJumaKhudonazarov
Thanks and how i can do it in  Web Mercator Auxiliary Sphere spatial reference? Do you have a guide or advice? It worked this way before when the sample size  were small
ZacharySutherby
Thank you,
Zach
DrJumaKhudonazarov
thanks  the new layer worked  but now I can not  see live updates from Survey 123 , refresh interval or action is not working
